Hi all,
It's Vinay here from Captronic systems.I am facing problem in installation of
PCI-6528 cards and while installing the drivers in IPC's.
The cards has to be installed in Industrial PC's(P-3, 550 MHz).There are 2
models of IPC's both using PX-14S2 backplane of
ICP(america)(http://www.icpamerica.com/products/single_board_computers/backplane
s/PICMG/PX-14S2.html#specifications) make.
The OS is Windows NT 4.0 service pack 6.I am successful in installing (DAQ
7.4
) PCI-RS-232 4port isolated card,PCI-RS485 4port isolated card,PCI-GPIB and
PCI-6503 with ER-16 without any problem in one of the IPC.In the same IPC i had installed PCI-6528 which is passing self test. when i am applying voltage to digital input lines it's not going high( same effect for DO's not getting continuity).
In other 2 IPC's i am facing problem in driver Installation phase itself.I had attached the document which contains the error what i had faced.In NI site i searched for the related topics i got one information to change the Driver CD or to copy the CD contents to hard disk.both I did that didn't work.
I installed the same driver version in the desktop PC, OS is same as IPC's
(i.e Windows NT 4.0 service pack 6).The system configuration is P-3 430 MHz.The PCI-6528 is working without any problem.
I hope these information are enough.Please tell me the reason why I am facing this problem.
VINAY KUMAR D I
