NI Home
Cart Cart | Help
You are here:
Reply
Member
mhawary85
Accepted Solution
OEM version of ni usb-6501
OEM version of ni usb-6501 contains IDC connector, i want to know what is the pitch of the pins in this connector in order to build a daughter board for it??
Trusted Enthusiast
AnalogKid2DigitalMan
Re: OEM version of ni usb-6501
I'm guessing it uses the IDC standard 2.54mm (0.100") pitch.
-AK2DM
Active Participant
SnowMule
It's a standard 0.1"-pitch 34-pin ribbon connector... description/dimensional drawings in the product information PDF.
Connector for the 6501 juts off to the side; unlike the 600x-series you can't just solder a header connector on the mobo and press the DAQ/DIO onto it.
Use something like this on the PCB, pick up a few of these connectors and a couple feet of ribbon cable to make your own connecting cables.  The hole pattern for the DIO is in the product manuals as well.
Member
mhawary85
THANK YOU GUYS FOR ALL YOUR HELP
I REALLY APPRECIATE IT
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
