04-19-2017 09:34 AM
Hello Everyone,
I have NI 6002 device and i have attached a flow sensor to the counter input of NI6002. How i can read the counter input so that i can count the number of edges(high , low points) .Pleas help. Thank in advance
04-28-2017 07:32 PM
Hello Alan,
You should be able to use the Counter - Count Edges.vi example from LabVIEW. Just go to Help » Find Examples... and when the Example Finder loads, expand Hardware Input and Output » DAQmx » Counter Input and you'll find the example there.
Select the device's counter in the Counter control and the PFI you connected the signal to in Input Terminal. You can either count rising or falling edges after selecting one in Active Edge, but not both.
Hope it helps!
