03-30-2006 03:32 PM
03-31-2006 03:58 PM
Hello Luke,
As seen in this benchmark KnowledgeBase for the USB-6501, the average time to update a digital output line is about 1 ms. Running LabVIEW on a Windows machine, you can generally get a time resolution of 1-2 ms. So my guess is that you can get fairly close to 100 ms, but it will be highly system-dependent.
Hope this helps,
Laura
02-09-2014 05:02 AM
Hi Laura,
As high as 1-2ms? I'm trying to generate a PWM for a servo motor (1-2 ms on time every 20 ms), but the output is jumping around 1 to 6 ms. 😞
02-09-2014 09:54 AM
Laura has not logged in for over a year.
If you look carefully at the document she linked, you will see that it only reports averages over 10000 updates. With any software-timed device the timing jitter is very dependent on the behavior of the operating system. So while the average may be near 1 ms, that may simply mean that 9999 of the updates were very fast while one took most of 10 seconds.
To do PWM effectively you need a hardware timed DO or a real-time OS.
Lynn
