10-19-2011 04:59 PM
I have built PXI systems that uses PXI 6534 for OWI communication with my Chip. I have written the software which uses this sytem for test and calibration. I am using PXI 2530 for switching the power and OWI pin from dut to dut. Recently, I heard that NI is dicontinuing the production of the PXI 6534 i/o card. I am wondering If my company needs to build new system, what I shouldI use in place of 6534 that don't require changing my software.
Mansoor
10-20-2011 01:59 AM
Hi Mansoor,
if you don't need 20MHz, you can go for the 6535 which is said to be software compatible.
I think there's even an adaptor cable available to use "old" 6534 cabling
Hope this helps
Oli
10-20-2011 10:17 AM
Hello Mansoor,
Thank you for bringing this issue to the forums. Yes, you are correct that we will be discontinuing the production of the PXI 6534. NI recommends that you use the new PXIe-6536/36/37 Digital Devices. Here is a product page for the PXIe-6536 which has a 25 MHz Digital I/O.
NI PXIe-6536: http://sine.ni.com/nips/cds/view/p/lang/en/nid/203682
You can only use this board if you have a PXI Hybrid Chassis or a PXIe Chassis. What chassis do you have?
Thank you,
Vimal Fernandez
10-20-2011 07:25 PM
Hi Vimal,
We have PXI 1042 and PXI 1044 chassis. I don't think PXIe 6536/37 would work with these chassis, but I can use PXI 6535. Am I right?
Mansoor
10-21-2011 01:46 PM
Hi Mansor -
Vimal is OOO today so I'll be helping you with your post. To answer your question, you are correct that neither of those chassis will work with any PXIe modules.
Speaking of the second question, the 6535 is a PXIe module as well and won't work in a PXI chassis. The discontinued PXI and PCI 6533/34 replacements are in the PCIe and PXIe form factors only.
I will apologize again for the abrupt end-of-life notice you received on these devices, it was an unforeseen supply issue with some of the parts on the board that caused the sudden obsolesce.
If you are looking into potentially purchasing another chassis (PXIe), then we would be happy to discuss your options and the best fit for your current and potential needs.
10-21-2011 02:26 PM
Mansor -
I was actually notified right after I posted the above reply that the PXI-6534 was actually REMOVED from EOL status. Some additional stock of the necessary parts were found and we will continue to sell the boards for a projected 2-4 years.
To answer your original question, there isn't really a drop in replacement for the PXI-6534, if you used DAQmx to program this device then the only transition gap would be from PXI to PXIe.
Just a note: If your application was programmed with Traditional-DAQ (Legacy) then the boards you replace the 6534 with (PXIe-6535/36/37) would not work with your application...without being reprogrammed.
I hope this helps answer your question, let us know if we can assist any further.
07-16-2013 05:37 PM
Benjamin,
From a software perspective, are the 6533 and 6534 the same? Or will I have to do some software modifications?
Ilham
07-17-2013 04:09 PM
You should be able to not modify your code.
