04-14-2008 12:53 PM
04-15-2008 03:48 PM
So there is not a GPIB0 folder under Devices and Interfaces in MAX, but there are folders for the Instruments? What version for MAX do you have? In addition, what version of 488.2 and DAQmx are installed on the computer? The version numbers are listed in MAX under the Software expandable and clicking on the driver in question ... the version is displayed in the middle panel in the Attributes tab (sorry if I am spelling it out too much).
You mentioned it previously was not an issue. Has anything changed? Did you download any new upgrades or software? If you recently installed new drivers, were the devices installed in the computer during installation of the drivers? Are the PCI devices detected in the (assuming Windows OS) Device Manager? Are there any yellow warning next to the devices?
Sorry for all the questions ... just trying to narrow down the issue.
04-16-2008 08:33 AM - edited 04-16-2008 08:35 AM
07-23-2011 03:40 PM
I got the same error message and followed the instruction: http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FF86256FFD005B827C?OpenDocument
But our folder: C:\...\National Instruments\MAX\Data\
is empty and there is no file named config3.mxs.bak. What could be the problem and how to solve it?
We didn't modify anthing in labview programee. The error message is attached here.
Look forward to quick response!
04-30-2012 10:42 AM
Solved the problem as well with the help of the
05-29-2016 04:50 AM
Solution:
1. Run the MAX as admin of your PC.
2. Tool --> Reset Conf. Data
3. Restart your PC
