Digital I/O
NI 9477 Dry circuit rating
Can the NI 9477 be used like a relay contact ?
Is a minumum amount current required to saturate the MOSFET switch ?
Brooks
(5,187 Views)
Hi B_Lind,
Yes, the NI 9477 can be used as a relay contact.  The MOSFET switch does not have a wetting current.  Because it is solid-state, there is no oxidation layer to burn through like there is when you work with electromechanical relays.
Good luck with your application!
Jared R.
Precision DC Product Support Engineer
(5,166 Views)
