Digital I/O
NI 9476 only DO0-DO8 are working
I have a NI 9476 in a cRIO 9025.  I've been programming an application and I noticed that if I wrote to DO13 I would alreays read a false value.  I could never set it true.
So I hooked up a 24V LED and wired the supply properly to see if the output was actually working.  It wasn't, and it turn out that only DO0-DO8 are working.  The rest do not even though I can read back the state I set in all the channels except for DO13.
The LED was the first time the NI 9476 has been connected to hardware.  Is this likely to be a faulty NI 9476 or perhaps a driver issue.  NI-RIO 15 is installed.
John
(3,536 Views)
Hi, I have a few clarifying questions:
Are you using the scan engine or the FPGA to access this module? What version of LabVIEW and Real-Time are you using?
I also just want to confirm, the NI 9476 has 32 DO, only the first 9 work? The rest, except for DO13, will read a true value, but still won't ouput a true?
Is it possible to measure the actual output from the DO?
Finally, could you post a simple version of your code where you are setting the outputs?
Matt G.
Product Manager
(3,512 Views)
Hi Matt,
Yes, I'm using the scan engine and labview 2014 32bit.  I'm not using a scanned variable read or write.  I'm simply dragging the variables from the project explorer to the vi.
I've even wired a boolean true constant to the variable just to be sure I wasn't doing anything stupid.  But when I read it, DO13 stays stuck at false..
You summarized me correctly except that DO13 will always read false.  DO0-DO8 outputs are correct, but DO8-DO31 outputs are always off even though they read back true when I set them to true.
I spoke to an engineer this morning and he was going to have the RMA people get in touch with me.
John
(3,507 Views)
Yeah, that sounds like the best next step!
Matt G.
Product Manager
(3,484 Views)
