07-08-2014 02:40 PM
Hi, I was wondering if a cDAQ-9178 chassis paired with a NI 9474 module would be capable of creating (3) unique 0-5V TTL signal? Would there be any obvious disadvantages to taking this route?
Thanks for your help in advance.
If anyone is interested in application to help guide the discussion:
I am trying to create 3 TTL signals to send to a PFI signal driver box, which will drive 3 fuel injectors. The 3 fuel injectors will be driven independent of each other to achieve different flowrates.
Mitchell
07-08-2014 02:49 PM
Simplifying this a lot more:
Can I create 3 unique square waves (50% duty cycle) with varying frequencies with a NI9474 module paired with a cDAQ-9178 chassis?
07-09-2014 03:08 PM
Yes, this can be done. Depending on the speed. You have 4 counters available in the 9178 that can be used to generate a pulse train.
