07-24-2013 11:36 PM
hi,
how r u every one ?
i have CDAQ-1988 with Ni 9403 Digital I/O but this module without cable or kit to use it how can i wire this module >??
thanks
http://sine.ni.com/images/products/us/ni-9403_l.jpg
Solved! Go to Solution.
07-30-2013 01:08 AM - last edited on 02-19-2024 10:42 AM by migration-bot
Hi Eng.Tareq,
You need 37-pin D-sub connector (i.e. DC-37) to connect to NI 9403. If you'd like to use NI's, there are two options:
- Front-mounted screw terminal type such as NI 9923, or
- Cabled connector such as 37-pin DIN Rail block with NI SH37F-37M cable.
Basically these options can be seen on the product page of NI 9403. Please contact your local NI office for purchasing enquiry.
Hope this helps.
Yodha
NI Singapore
