08-21-2013 03:18 PM
I am trying to use NI 9402 to generate two trigger signal from 2 different lines. The time interval between these two trigger pulses is critical (should be accurate at 10 or 25ms from each other)
I think software timer is not accurate enough for my purpose
Is there a way to make this possible? Please help!
Thank you,
08-22-2013 09:17 PM
To clarify, you would like to generate a signal on two different channels as simultaneous as possible?
You should be able to write to two channels within 10 ms of each other by using the method described below.
Simultaneously Read or Write to Multiple Channels
http://digital.ni.com/public.nsf/allkb/0C1ADEF06A54AB2D862575040066FD51
10-17-2013 10:10 AM
10-18-2013 12:44 PM
Shanyechungu,
The 9402 is a 55ns capable high speed digital I/O device with hardware triggering capability. This should be more than adequate for your desired pulse response.
Mark B.
10-18-2013 08:12 PM
10-21-2013 11:18 AM
LabVIEW ships with plenty of example DAQmx code that should be enough to get you up and running, creating triggered pulse outputs. Most can be found under Help>>Hardware Input and Output>>DAQmx>>Digital Output. If you have specific questions on the functionality of the example code please feel free to post. Most forum users will not simply 'give you code' but encourage you to understand the examples and implement them for yourself. Truly, this is the only way to learn.
10-21-2013 11:23 AM
