11-23-2014 11:28 PM
DearEngineers,
I am using NI 9401 DIO card with cRIO 9073.
I should use 1 channel and generate the frame of 96 bits. The bits will be user configurable. How doi do it. If i get answer to this i shall be able replicat the same with other 3 channels. So my Agenda is to have the frame format generated using 4 independent channels.. Please help me out with the solution and the help shall be greately appreciated
Baud rate of the signal shall be 9.6kbps.
Bhargav
11-25-2014 10:23 PM
Dear All,
Can any body help me with how do i find the CRC for 8 byte Data. Along with Manchester Coding for 8 byte Data
