Hi CAVR87,
In the specifications you can read:
Maximum input signal switching
frequency by number of input
channels, per channel
8 input channels.......................... 9 MHz
4 input channels.......................... 16 MHz
2 input channels.......................... 30 MHz"
It means if you would like to measure 8 input channels, you are not able to measure correctly a signal with a switching frequency higher than 9 Mhz.
In your case you are in the range of 10 kHz so you can easily measure it with this module.
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
