06-25-2014 09:59 AM
Using a 9174 chassis and NI 9401 Digital I/O I can not get the output to switch faster then 10 ms. I would like to have the output turn on off @ 15Hz 9% duty cycle which would roughly be 6ms on 66ms off. Does anyone have any idea how I could achieve this?
06-25-2014 10:15 AM
If you are using software timing (telling it to go high, then telling it to go low), you will not get the speed you want. I'm not totally sure if it will work, but you could try setting up the digital outputs to output a waveform. But you may need to go to a cRIO and use the FPGA in order to get the timing you want.
06-25-2014 01:33 PM
I tried a few different ways. One I simply had a couple of timers and some logic but once the pulse reached 10ms I could not reduce it any further. I also tried the output of a function generator but again was not able to get the pulse below 10ms. I will have to look into the cRIO and fpga at this point do not know much about it. Thank You for your help.
06-25-2014 02:22 PM
Actually I have another question if you do not mind me asking? Why is it I need the compact rio and fpga? The specs said 2 outputs should be able to switch at 20MHz so why do I now possibly need something different? Just trying to understand the situation. Thank You again
06-25-2014 03:06 PM
