Digital I/O
NI 9237 Input
I am trying to understand if I can connect a 6-axis force sensor(full bridge) , composed of 6 wheatstone bridges with a single output cable, to the component NI 9237 present in my CompacRio configuration or if I can just convert the signal and use a simple current analog input module like the NI 9208. Are there any advantages in using a bridge adapted module?
(4,212 Views)
You can connect up to 4 bridges to the 9237, for further information consult the link below:
http://www.ni.com/pdf/manuals/374186e.pdf
Regarding the Benefits of the NI 9237 for Bridge-Based Sensors there is a white paper explaining it much better than I could do:
http://www.ni.com/white-paper/52769/en/
Jovan N. - Application Engineering
(4,152 Views)
