10-18-2012 05:45 PM
I am planning to buy NI low cost multi-function DAQ - NI 6501.
In my application, I would like to generate a pulse train (+5V and 0V - TTL ) with 1600Hz to 2000Hz (50% duty cycle is fine ) to control the speed of a stepper motor. Is it possible to generate pulses in that freq range with the help of NI 6501. This seems the one I can afford now. However, can I achieve my task with this hardware.
Advise and suggestions are appreciated.
Best,
Abhi
10-18-2012 08:21 PM
10-20-2012 09:38 AM
Thanks Dennis,
I looked through the various DIO modules available from NI. But apart from PCI,PCIe and RIO modules they dont seem to have any hardware timed boards in USB.
I am just looking for a DIO that can give out 2KHz max pulse rate to run my stepper motor. Is there any product that is low on budget and still meet this requirement ?
Abhi
10-20-2012 10:52 AM
10-20-2012 01:11 PM
The 6501 is cheap, but it's all software-timed... which means there's a lot of limitations to it in terms of speed and accuracy.
Might look into a 6211, those have some hardware timing capabilities, and the X-series DAQs have morec apabilities on the digital I/O's.
But to do what you want to with a 6501 .... I don't think it's gonna happen.
11-13-2012 11:17 PM
To add to this, also consider the current drive your motor requires. Many digital cards may not offer the current you need for your load. Don't short-change yourself trying to cut corners!
