05-29-2014 06:28 PM
Hi All,
I am using Ni-6501 device.
But i need more port\lines.
What kind of device can i use to have more than 24 port/lines IO???
Please help. Thanks brothers..
Jessie
05-30-2014 06:11 AM
The 6509 has 96 DIO lines. Will that be enough for you? There is a USB, PCI, PCIe, and PXI version available.
06-02-2014 12:01 AM
Is there any device that have a combination of SCL/SDA and more that 24 Digital I/O port/lines?
I have here Ni-8451 device but fewer digital I/O port/lines.
06-02-2014 02:46 PM
The easiest and cheapest answer answer for increased channel count in an I2C/SPI application would be to simply buy multiple USB-8451's. The alternative would be to use a High Speed DIO card or FPGA but that would require that you program all I2C or SPI communication yourself. You would have to build your clock and data waveforms yourself and the hardware is more expensive than buying multiple 8451s.
06-02-2014 02:47 PM
What specifically is your application?
