10-08-2012 06:48 AM
Hi.
I'm using 2 Meilhaus ME630 relais-cards together with 2 additional ME631 external blocks.
I can use both the internal digital output blocks on the 630s (devices 0/1, subdevice 2 in ME PowerLab), but I cannot use the two digital I/O-blocks on both 631s (subdevices 3/4).
Does anyone have any experience with the Meilhaus hardware and can help me somehow?
In the attached file, I can switch the first relais of the subdevice, using the LV-button for the last. Connecting the counter to the channel-input of the configuration-sub.vi gives an error, as does any single input which is not zero:
"Fehler 3 ist bei meIOSingleConfig.vi aufgetreten
Mögliche Ursachen:
LabVIEW: Interner Fehler. Zugriff auf falschen Speicherbereich.
NI-488: GPIB-Controller wurde nicht richtig adressiert."
Thanks in advance!
10-11-2012 06:13 AM
Got it solved. See attachment. Maybe it's useful for someone.
