Digital I/O
MIO software error on cdaq 9188 / NI 9477
Im using cdaq 9188 controller and 7 different io modules like.
1: NI 9426
2: N I9477
3: NI 9205
4: NI 9264
5: NI 9485
6: NI 9211
7: NI 9222
When i run for Digital output  using daqmx create channel.vi , and write digital channel i set TRUE as auto start task.
here i am getting error as:
Error code  = -225202
Error description = Internal softwware occurred in MIO software. Please contact national Instruments support.
What could be the reason, please suggest me:
Balaji DP
(7,910 Views)
please do reply.. i guess this is most active board
Balaji DP
(7,905 Views)
http://digital.ni.com/public.nsf/allkb/1B7C591595D03F82862574120068AB55
This link might be helpful. It is infact the only link I can find regarding the error you mentioned.
(7,894 Views)
I also faced the same error. same cdaq model.
tried both in your link but no luck.
(7,394 Views)
Hi Balaji,
How do you rectify the problem?
can you share?
thank you
(7,392 Views)
Check the firmware version of your 9188.  Mine was shipped with 1.1.0f0; upgrading to 1.5.1f0 fixed my MIO software error.
New firmware here: http://www.ni.com/download/ni-cdaq-9188-firmware-1.5.1/4302/en/
(7,028 Views)
Hi Matt,
Yes yes..it works perfectly after i update the firmware..
thank you Matt.
(7,021 Views)
