06-07-2012 05:44 AM
Hello
I have an MCA card that takes TTL pulses to Start and Stop itself. I am looking for a suitable NI hardware that I can control with Labview and when certain condition is met, the LAbview will tell the hardware to output the TTL pulse.
Will NI USB 6501 solve the purpose?
saurabh
06-07-2012 09:55 AM
How fast and accurate of pulses do you need? The 6501 only has software timed outputs. This means that your code has to explicitly write a TRUE to the line and then write a FALSE for a positive pulse. Being software timed, you will not have consistent pulse lengths.
06-07-2012 12:15 PM
The MCA card takes TTL pulses, so +5V (FALSE) should do. What I am trying is that Labview checks a temperature controller. everytime the temperature is equal to the setpoint, it will 'ask' the 6501 to output +5V TTL pulse. This pulse will fire up the MCA.
About the stability, i dont know. I have tried it with a DC source of +5V , the pulsing done by touching the output wire to the MCA port. And it works. Please dont ask me to LabVIEW the DC power supply, now!
I dont have the whole manual now, but the related part goes like-
"Start with DigIO Input Dig.4" and then press the start button.
Acquisition will start when you short cut the DigIO port 4 with ground, and
stop when you release the short cut. The DigIO port has a pull-up
resistor to +5V. If you want the opposite behaviour that it should start
with +5V, check "Invert".
This DigIO port is the one I tried with the DC source.
thanks
Saurabh
06-07-2012 01:11 PM
It sounds like the timing of the pulse doesn't really matter if you are doing it by hand with a power supply. As I stated above, simply write the high value to the DIO and sometime later write the low value. The 6501 will work just fine.
07-31-2012 06:14 PM
Hi, I would like to output TTL pulse to trigger our laser source. Does USB 6501 work well for this function? the frequency is less than 1 Khz. Looking forward to your answer.
Thank you very much for guidance.
