04-10-2013 11:07 PM
Is there a Labview example for capturing data to a file using the HSDIO the Direct DMA instance of
the niHSDIO Fetch Waveform VI
PXI-6561 card
The strobe clock rate is 40MHz
Continuous data to files is needed
04-11-2013 06:17 PM
Hi Isutiger,
Here is an article that contains an example that should be pretty close to what you are looking for.
http://zone.ni.com/devzone/cda/epd/p/id/5271
04-11-2013 08:02 PM
That is the example that I started with. I does not support a external clock rate of 40Mhz with the PXi chassis,PXI-6561 card and computer that I have. The memory in the card overflows and the application stops.
I changed the data type to U16 to match the PXi cardt
I played with external clock rate and the streaming could keep up with an external clock rate of 37MHz which is a little slower than what I need.
Thus I was looking for how to use the DMA VI...it has an input of Address, but don't know what that is?
04-13-2013 07:25 PM
Hi Isutiger,
Can you please send me a screenshot of the error you are seeing.
Also, can you please tell me the exact name of the DMA VI you are looking into?
Thank you,
04-14-2013 07:54 PM
I am not near my PXi chassis So I'll have to send yuo a screen shot on my next posting
C:\Program Files (x86)\National Instruments\LabVIEW 2012\instr.lib\niHSDIO\niHSDIO.llb\niHSDIO Fetch Waveform (Direct DMA).vi
