10-21-2013 02:30 AM
I am working with an application where I want to control 32 outputs with labview. Each output shall be able to handle 1A and the output voltage shall be 24V.
Is there such a unit?
Rui
10-21-2013 12:31 PM
Not without some signal conditioning.
NI makes a relay board kit that you can connect to a power supply capable of the power required, then connect your devices to the relay block.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/10689
(We had all those relays controlled by a couple of PXI Digital I/O boards.)
10-22-2013 01:54 AM
Thanks for your reply.
I was considering this:
http://deditec.de/en/module/prod/can/ro/ro-can-pwm32.html
do you have any experience with deditec and labview?
Rui
10-22-2013 01:25 PM
What are you trying to accomplish in the end?
If you're trying to switch solenoids/relays on and off... while that CAN controller will probably work, it's adding a lot of unnecessary complexity to the system. Do you need PWM?
10-23-2013 01:22 AM
I want to control a number of LED stripes, like these:
http://www.sloan.ch/en/products/complete-systems-led-modules/flexi-print-a-backlight.html
from my labview application. I also need to dim them so that's why I need the pwm functionality.
10-23-2013 03:14 PM
If your system can speak CAN and that controller has the power to run it, looks like a reasonable approach.
Or try something like this... http://www.heroicrobotics.com/
10-24-2013 03:39 AM
Interesting. Thanks a lot for your suggestions SnowMule!
