10-09-2015 03:57 AM
I'm using PXI-6509 and this sentence from the manual:
"You can use each of the DIO lines as a static digital input (DI) or digital output (DO) line,"
leads me to believe that each individual DIO can be set as input or output (even within ports), but theimage:
shows that these ports cannot be set as inputs and outputs within the same port.
On another card 6284, with DIO's, I can set them individually.
Can someone confirm that the 6509 is acting correctly?
Best Regards,
Adrian
10-09-2015 11:01 AM
If you create a task then it appears you can control an individual DIO line.
10-09-2015 11:15 AM
Using the 6509, I have had inputs and outputs on the same port. I'm not sure why the Soft Front Panel is not letting you do that.
10-12-2015 01:01 AM
Hi guys,
Thanks for the feedback.
How I found the problem was as follows:
(Is my approach OK?)
So after this I went to look at the soft panels and saw there that the lines were not individually controllable.
It certainly feels wrong that this could be the case.
Thanks again,
Adrian
10-12-2015 05:36 PM
Hi ARL00000000000…,
I experienced the same behavior in the test panel. I'm doing more research to determine if this is correct behavior.
10-16-2015 01:39 AM
Hi Defective,
Have you had any luck with this issue?
It still seems weird that it would be the case.
Adrian
10-19-2015 12:08 PM - last edited on 02-07-2024 04:39 PM by migration-bot
Hi Adrian,
I looked up the product page of the device and found the following information: line direction selectable on an 8-bit port basis (https://www.ni.com/en-us/support/model.pxi-6509.html). This is consistent with what you are seeing in LabVIEW and NI MAX.
10-20-2015 12:57 AM
Hi Luke,
Thanks for the reply. Unfortunately the link posted leads to a "Sorry, page not found".
Best Regards,
Adrian
10-20-2015 10:09 AM - last edited on 02-07-2024 04:39 PM by migration-bot
@ARL00000000000000 wrote:
Hi Luke,
Best Regards,
Adrian
He had an error with the URL. Easily corrected if you had observed what was in the URL box in your web browser.
10-20-2015 10:13 AM - last edited on 02-07-2024 04:40 PM by migration-bot
@Defective_Luddite wrote:
Hi Adrian,
I looked up the product page of the device and found the following information: line direction selectable on an 8-bit port basis (http://sine.ni.com/nips/cds/view/p/lang/en/nid/13261). This is consistent with what you are seeing in LabVIEW and NI MAX.
On page 3 of 10 of the linked Data Sheet, it states You can individually program each 8-bit port on an NI 6509 to be input or output
That is very very confusing.
