Would it be possible to add a "Non-Clocked Bit" vi into the I2C Reference Library so that it would add a clock cycle where SDA and SCL are both low? This would provide two benefits.
1.) It would make it much easier to visually see where one byte ends and the next byte starts when debugging with a scope.
2.) It could be placed before an ACK bit to provide a pseudo clock-stretch for devices that need a little extra time to ACK.
If someone could please provide instructions on how to modify the existing "Add Clocked Bit" block to make it a "Add Non-Clocked Bit" block, and then add it to the existing library, that would be a life saver!
