If you disconnect the PMU, you will have the option to go to tristate or your previous digital state, but not ground. Forcing 0V is probably the closest you can get to a GND like behavior. The default line state is tristate for this device, which will leave the line floating if there is no active driver.
Kyle A.
Senior Applications Engineer
