01-28-2008 04:19 AM
01-28-2008 08:16 AM
It depends on the timing requirements you have. The 6501 is software timed so you will have to depend on the timing resolution and jitter of windows. Use the timed loop/structure or use the wait/delay functions on the timing palette. At it's most basic, you would set the DAQmx Write to a high, delay x microseconds, set the DAQmx Write to a low.
01-29-2008 09:38 PM
03-20-2008 09:56 PM
03-26-2008 05:48 AM
05-10-2013 06:05 AM
I have looked at your thread and i am facing the same issues with my usb 6510 here. I want to trigger pulse train to switch on and off for the solenoid valves but do not know exactly how to do it. Can you attach your final files on?
Thanks in advance
