Digital I/O
How to read multiple analog signals simultaneously with a USB-6211
Hello, I am trying to read 16 analog signals going into a USB-6211 all at the same time using Hardware timing. So far I have been able to read continuously from one input in a seperate project but I have no idea how to read multiple lines at once.
Thank you for your help!
(3,017 Views)
In order to better understand how to be do this I suggest to use the  "Voltage - Continous Input" example that you can find going to Help> Find Examples.
I have attached an image about how you can do this. Basically what you need to do is going to the Physicall channel, click browse and select the channels you want to plot.
Hope this helps!
(3,000 Views)
