10-22-2013 03:19 PM
Hi, I am a newbie and I have no idea how one could read a DHT22 sensor from a USB Serial which is connected to Arduino and to make a certain amount of Humidity the LED light go on. Is it even possible to acquire data from DHT22 sensor like that?
I would be really thankful if you could help me to figure out a base or an example where to start, thanks in advance.
10-22-2013 03:41 PM
10-22-2013 04:12 PM
Allright, good tip, I'll post there also.
Allthough I am talking about a Digital sensor which sends data to Arduino to a digital pin and than through serial port to Labview through which I would get a graphic out.
10-22-2013 05:46 PM
10-22-2013 05:55 PM
To be honest, your correct, sorry for my inconvienience.
11-20-2013 12:09 AM
Then how to show the sensor data on labview?
11-20-2013 02:37 PM
You write a program for the Arduino that reads the data. You format it as you wish (i.e. ASCII text, hxe, etc) and you write that data to the Arduino's serial port. Your LabVIEW program will read the data at the port and display it.
To make the serial communmication more robust, I would suggest you use a terminator at the end of each serial communication. This is typically a carriage return or a line feed.
09-27-2014 06:56 AM
hi
i am very new to use labview and arduino.... i am assigned a project of data logging to temperature and humidity .. for which i am using DHT@@ sensor .. can one help me out to make complete VI block on Labview ... wwith no error ... waiting for reply of you guys.....
09-27-2014 06:58 AM - edited 09-27-2014 07:01 AM
waiting.............................
09-27-2014 08:01 PM
So you are appending to an old thread that is already marked as solved and two minutes later you are posting again?
Are we a little bit impatient? 😮
