06-19-2014 06:19 AM
Which model "96ch PCI DIO" ?
I f I use 2 x 96 channel PCI Card , how to sync 2 cards.
06-19-2014 06:34 AM
I have had a lot of luck with the PXI version of the PCI-6509. Each line should be able to drive your SSR, but check all specifications to make sure.
These DIO are software timed and are port addressable (each port is 8 lines). So I would try to group the solenoids that you need to be perfectly together into ports and then write the value to the ports as needed.
