Digital I/O
How to control more than 200 separate solenoid valves ?
Which model  "96ch PCI DIO" ?
I f  I use 2 x 96 channel PCI  Card , how to sync 2 cards.
Message 11 of 12
(2,536 Views)
I have had a lot of luck with the PXI version of the PCI-6509.  Each line should be able to drive your SSR, but check all specifications to make sure.
These DIO are software timed and are port addressable (each port is 8 lines).  So I would try to group the solenoids that you need to be perfectly together into ports and then write the value to the ports as needed.
GCentral
Message 12 of 12
(2,534 Views)
