02-11-2013 07:43 AM
I recently brought NI USB-6509 (96 channel USB to Digital IO) and tested ok with Labview. But i wanted to detect and control the same device in microsoft excel. Can anyone suggest me some solutions to work on excel with this device?
02-11-2013 12:46 PM
02-25-2013 08:58 AM
Hello Dennis,
That was very useful for me to start with the instrument.
I have a problem where the device is resetting after every read.
My application is to read the entire port and modify one bit in the port. Here is how i am doing the activity
Step 1 : Create Task handle for both write and read activities
Step 2 : Read the port and store in buffer
Step 3 : Modify read buffer
Step 4 : Send the modified data to same port (bit modification)
This works fine first time. When i repeat the same from Step 2, all ports are getting reset to defualt values instead of previous data.
I am absolutely blank why device is resetting when i am reading.
I will be thankful to you if you could help me in this.
I am also attaching VB code for your reference.
