06-19-2014 02:22 PM
06-20-2014 01:57 PM
Hey scubadood,
I think this article may make your question about current output of the 6210 more clear: http://digital.ni.com/public.nsf/allkb/AD24775684BDACA58625766500673D9A?OpenDocument
The 6210 has a self-resetting fuse that caps the total current output using external power at 350 mA. If one pin still cannot supply enough current for you, you can use more pins in parallel to get the maximum 350 mA.
As for hooking up external power, the +5V pin, pin 10 on the 6210, can either be an output or an input. To use it as an input, simply wire your external 5V supply's V+ to this pin and the ground wire to a D GND pin.
Ryan
06-24-2014 01:51 PM
Thanks for the response Ryan!
I was able to wire the four digital output pins in parallel to achieve the desired output power. However I do have a concern of damaging the device (NI USB 6210). I have read some articles online that suggest it is possible to damage your device this way. Should i be concerned about damaging my USB 6210 with this settup?
If damage to the device is a concern, would it be better to use a different NI USB device such as the USB 6003 or USB 6009 that will allow at least 150mA output on the +5V terminal ?
Thanks again,
Scubadood
06-24-2014 03:00 PM
06-25-2014 09:04 AM
Below is the link to the USB 6003 i was refering to. The +5V output terminal is able to supply 150mA. Do you mean to say that they dont make this product anymore?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212385
06-25-2014 09:31 AM
06-25-2014 01:22 PM
Have you thought about using a solid state relay?
06-25-2014 01:33 PM - edited 06-25-2014 01:34 PM
That is what the HN22005 that the OP is using.Nevermind. I confused this thread with another one that I was following...
06-25-2014 01:44 PM
I had not considered that. I was just working with what parts were at my disposal. however now i am considering trying a different relay that will not require as high of a current. Would the SSR require less current to turn on but still be able to drive a 24V actuator on the output?
Thanks!
06-25-2014 01:52 PM
Thanks!
Just give Digikey a good search and you'll find something. The control current is definately less than a normal relay.
