08-14-2015 05:11 PM
Hi Fellow Labview users,
I just started using LabView and I'm very new at it. I know the basic understanding of how it works and got something to work but I need it to be more efficient.
I'm using Measurement Computing's USB-DIO96H DAQ, which has 96 digital inputs. I use the DAQ to acquire relay activations and record the number of times the relays flips.
Basically I created one digitial input read, and then copy & pasted it 95 times... it works but I know this is not the best way to use LabView.
How can I change the digital input (dev0/1stPortA/Di1) to be multiple so that it iterates through all 96 channels without copy and pasting the same diagram over and over?
Leon
Solved! Go to Solution.
08-14-2015 05:45 PM
08-14-2015 06:22 PM
Thanks for the quick response! Yes, the input does allow me to do multiple channels with 0:8.
However on the output side I tried to create an boolean array to scan through the channel lines but LabView gave me an error on type mismatch. (Type of source is boolean, sink is 1 D array boolean). What is the correct way of displaying the multiple channel?
Cheers,
Leon
08-14-2015 08:20 PM
08-18-2015 05:32 PM
Thanks Dennis, That was very helpful 🙂
ULx's read VI has 1 D boolean that allows me to display the N-Channels in arrays. Now I can delete the rest of the redundant lines and use that one N-Channel read.
