04-16-2015 07:00 PM
Hi all,
I just got a Sensirion SHT71 for humidity measurement. I am new to digital I/O field so I feel unclear about how to connect this sensor to the DAQ.
The DAQ I am using is PXI-6225 hooked up with a SCB-68A connector block.
And the sensor has 4 pins (1-SCK: Serial Clock, 2-VDD: Source Voltage, 3-GND, 4-DATA (bidirectional))
Detailed manual can be found here http://www.sensirion.com/nc/en/products/humidity-temperature/download-center/?cid=8574&did=68&sechas...
So I am wondering what are the corresponding connectors on SCB-68A to those pins of the sensor. I can see the GND goes to the D GND for sure and the VDD is supposed to be connected to +5V. And I am not sure to which two connectors SCK and DATA should connect...
Reference label of SCB-68A can be found here: http://digital.ni.com/public.nsf/$CXIV/ATTACH-AEEE-8ZRTL5/$FILE/S_Series.pdf
Thanks.
04-17-2015 03:36 PM
Hello abright,
I have been looking at your case the whole day, analizing the circuitry of your application.
From what i can tell from the Reference label of SCB-68A : http://digital.ni.com/public.nsf/$CXIV/ATTACH-AEEE
If you have further questions regarding the pin out of the device please let me know.
Kind regards,
IronBrotha
AE CR
