07-06-2012 02:32 PM
I am trying to run HSDIO example "Dynamic Generation with Repeat Mode.vi". There is one vi that is in the example that LabVIEW cannot find: "niHWS Retrieve Digital Waveform U16.vi". How to I get this vi? Is it part of a package? I have already installed HSDIO (my system is brand new).
07-09-2012 02:40 PM
Hi j_osh_o,
The niHWS Retrieve Waveform.vi is part of the Hierarchical Waveform Storage (HWS) Software. The KnowledgeBase, here, explains how you can obtain NI-HWS. If you do not have NI-HWS API on your system, I believe installing the latest version of NI-SCOPE, NI-FGEN, or NI-HSDIO should add the VI that you are missing.
07-09-2012 06:28 PM
Hi j_osh_o,
This was reported to R&D (CAR# 306801) for further investigation. I believe you might be experiencing the problem described at the KnowledgeBase, here. The niHWS driver is not supported in LabVIEW 64-bit. As stated in the aforementioned KnowledgeBase, the current workaround is to use a different file format such as tdms.
07-10-2012 04:34 PM
I have installed NI-HSDIO 32 bit from the disks that came in the box with my PXIe-6544 cards. Can't remember the version (1.8???). Is it possible that this version is so old that it does not have the NI-HWS included? I will try to install the latest NI-HSDIO, maybe this will have the HWS in it?
07-11-2012 11:06 AM
You can determine if you have NI-HWS installed by going to the Measurement and Automation Explorer (MAX) and expanding the Software section.
Do you have LabVIEW 64-bit? You can determine which version of LabVIEW you have by going to Help>>About LabVIEW.
