Digital I/O
High Frequency sampling rate myrio
Greetings.
I am a new user, I am stuck in high frquency sampling rate, (using myrio, high throughput, n samples to get an analogue input ranging 250khz to 500khz) the example provided in dircetory is not working on my myrio, it disconnects from the comupter and stops working (untill I change the port again, in the next run, same issue again). What do you suggest?
High Frequency Sampling.lvproj in the labview\examples\myRIO\High Frequency Sampling
I've tried changing the time rate but same disconnectivity upon running the code (Continuesly).  Image attached.
How to get rid of the disconnectivity error? the code block is that same of the example mention earlier.
(2,977 Views)
How are you? Can you provide a screenshot of the error once the myrio disconnects? I'd like to investigate further.
LuisG.
(2,942 Views)
