03-14-2011 03:41 PM
03-15-2011 01:25 PM
Hi Scott,
Does your device support digital filtering on DIO lines? If so, you can use that feature to debounce the signals.
Brad
03-15-2011 10:44 PM
Hi psuedo!
I apologize for the difficulty you are experiencing. If you do have an issue with "bouncing" on you digital line, there are assuredly ways around this depending on the specifics of your application. However, for the time being, could you please inform us of the exact examples you have been referencing while creating your program?
Michael G
05-05-2014 02:58 AM
can you post the .vi with the solution.i am currently working on the same thing and i would really appreciate your help.
05-06-2014 12:26 PM
Hi myntranike,
Are you trying to count the number of bounces with shift registers, or are you trying to filter out bouncing in your signal? Could you give us a bit more information about what you are trying to achieve and which (if any) LabVIEW examples you are using?
David
