Digital I/O
Half Period shifted Signal without copying code?
Hi everyone!
Here is the code which generates accurate PWM for Half bridge Control with programmable dead-time, now here is the issue i want to shift the same signals on two DIO's with half the period of the signal. i ve tried following:
1. I copied the same code in FPGA and delayed it with half period using a wait( but it is consumes double resources and some times the half period phase difference is also not accurate).
I need some other technique to shift the same signal by half-period( or copy paste the same signals onto 2 other outputs by not copying the same code and thus saving resources). Any help is appreciated.
azy
(5,264 Views)
Hey,
why do you use the sub vi two times?
Do you use a NI modul and even if which one?
regards
Patrik
(5,197 Views)
Hello patrik,
Thanx for the reply.
i am using the NI9401 module for PWM signal generation, and i use the subVI 2 times because the rising edge delay has to be at both edges of a pulse, if there is dead-time at starting edge and not at ending edge there might be a short circuit between high and low side mosfets. do u have any idead to copy code with halp period shifted without duplicating code in FPGA ??
Best Regards,
azy
(5,192 Views)
Hey azy,
I´ve two links for you. I hope they will help you.
http://www.ni.com/white-paper/3254/en/#toc6
https://decibel.ni.com/content/docs/DOC-1065
Will the frequency stay constant or do you want it variable?
regards Patrik
(5,178 Views)
