09-19-2013 06:52 AM
is it possible to stream with HSDIO generating data and acquiring data simultaneously? I could barely stream continuously my generation data, and when I try to acquire data at the same time, I got errors. The error is either in generation session or acquisition session. I split the generation and acquisition in 2 different loops in main program.
Yan.
09-19-2013 07:01 PM
Yes ,it can, but I cannot tell why error happens, since I don't see your code.
09-20-2013 08:30 AM - edited 09-20-2013 08:32 AM
Hi Kate,
thanks for your answer, I guess its just how bad I've programmed my application. I've tried to run both generation and acquisition in 2 different VI's and it works. Problem is there in my main program. I think I still need to learn much. Perhaps I'm using too much global variables as indicator in my subVI's which makes LabVIEW runs slower.
regards,
Yan.
