06-16-2015 08:57 AM
I have a system that is not seeing the SCXI-1000 chassis. MAX sees the PCI-6250, but nothing els. The SCXI-1000 config does not show the 1349 interface. How do I get it to be selectable?
Since it does not see the 1349, it also does not see the SCXI-1180 connection
WinXP/MAX v4.3.0/SCXI-1160 x2 cards in chassis
06-16-2015 03:59 PM
Found primary problem, SCXI-1160 jumpered for DIO, needed MIO......
06-17-2015 02:12 PM
Tom,
Is your system working now? Also you have manually added your SXCI to MAX correct?
06-17-2015 03:04 PM
AE NI
yes/no
Max is configured and seems to see everything OK.
Unfortunately, the runtime software does not see the rack and it's boards. Will have to dig some more.....
thanks for the reply
