07-28-2013 02:39 PM - edited 07-28-2013 02:40 PM
I am using a AT-MIO-16XE-50 DAQ card and labview 6.1 to generate frequency divider. The first thing I want to do is to input a continuous digital signal into the program so I can divide it. The attachment is the program I am using. It is quite straightforward, just read the signal and then output it and put all of them in a while loop to get a continuous pulse. But when I want to observe the waveform on oscilloscope, I got some unregular square waves.
I am still a freshmen to labview. It will be appreciated for any one's help!
07-30-2013 02:25 PM
If you're just getting started with Digital I/O with Traditional DAQ, I would take a look at some of the examples to see how to structure your code to do both input and output. There is one here (http://zone.ni.com/devzone/cda/epd/p/id/1113) that should give functionality similar to what you are looking for, but if you want more examples you can navigate to the examples by following the article here (http://digital.ni.com/public.nsf/allkb/46D0C7360A10D25F862571B5007B4411), so long as you have installed them along with Traditional DAQ.
07-31-2013 09:07 AM
Hi Matt,
Thank you for your reply! I will read those materials first. I found the computer is too old and run very slow. This really effect a lot. We will change another computer and have try again.
