05-12-2014 04:37 PM - edited 05-12-2014 04:43 PM
I have a NI9402 mounted on a cDAQ-9171 chassis and I want to generate a binary signal (1MHz) and export the clock that it is generating the binary signal.
After that I want to read the data. I import the clock and the data line to a SCB-68 card. I want to use the imported clock as a reference for sampling the data.
Write Code (NI9402 mounted on a cDAQ-9171 Chassis) :
uInt8 dataWrite[8] ={1,1,1,0,0,1,1,1};
DAQmxCreateTask("",&taskHandle);
DAQmxCreateDOChan(taskHandle,"cDAQ1Mod1/port0/line1","dataOut",DAQmx_Val_ChanPerLine);
DAQmxCfgSampClkTiming(taskHandle,NULL,1000000.0,DAQmx_Val_Falling,DAQmx_Val_FiniteSamps,8);
DAQmxExportSignal (taskHandle, DAQmx_Val_SampleClock, "/cDAQ1Mod1/PFI0");
DAQmxWriteDigitalLines(taskHandle,8,1,30.0,DAQmx_Val_GroupByChannel,dataWrite,&sampsPerChanWritten,NULL);
Read Code (SCB-68 card and PCI-6534):
uInt8 dataRead[8];
DAQmxCreateTask("taskHandle",&taskHandle);
DAQmxCreateDIChan(taskHandle,"Dev1/port0/line0","",DAQmx_Val_ChanPerLine);
DAQmxCfgSampClkTiming(taskHandle,"/Dev1/PFI2",1000000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000000);
DAQmxReadDigitalLines (taskHandle, 8, 30.0, DAQmx_Val_GroupByChannel, dataRead, 8, &sampsRead, &numBytesPerSamp, NULL);
DAQmxStartTask(taskHandle);
1) With the scope I am only able to see the first pulse of the exported clock, not the 8 pulses that I should see. Am I exporting the clock correctly ? Please see the attached files: cDAQ-9171 and NI9402 connections diagram from NI MAX.
2) I am interested in using DAQmx_Val_ContSamps because in the future I would recieve a variable amount of data. When I execute this code looks like DAQmxReadDigitalLines () blocks the read program waiting for more data. How does exactly the buffer (set to ContSamps) and the ReadDigitalLines work together ?
Thank you very much
05-13-2014 08:42 PM
Hi Coquivhdl,
Could you provide a bit more information regarding the functionality of your defined tasks? Are you trying to write data to 8 lines with each sample, or 8 pulses on one line? It might be helpful to add a few comments accompanying your code to answer these questions.
Thanks!
