Digital I/O
Digital voltage range limit (less V)
Hi
My first post here.
In the Datasheet and in the examples i was not able to find a solution for my problem:
- output voltage digital 0-5V <-> input FPGA (3V3)
because i am communicating with a FPGA i have a problem with the output voltage of the USB-6221 to the FPGA.
Is it anywhere possible to change the digital output voltage range 0-5V? The other way is no problem, because the USB6221 accept 2.4V as an high (3V3 output of FPGA)
I am looking for an solution per CVI property to limitate the voltage range
-> the last solution will be a very simple voltage divider. But i need this for more than 2 lines.
Thanks for your help!
(5,180 Views)
I found an attribute
Set Chan Attribute
-> logic family -> DAQmx_Val_3point3
but this is sadly not supported by the USB-6221
is there any other way, except external circuit ?
(5,171 Views)
Hello floxe,
we also have devices that support LVTTL. But as you already mentioned USB 6221 doesnt have that feature.
So you eather have the option of purchasing another device or using an external circuit.
Best Regards!
Moritz M.
(5,155 Views)
