01-22-2013 01:20 AM
Im using NI USB 6289 DAQ and trying to do the following:
- Write digital data output serially in line 0 (port 0)
- Sample clock is generated using PFI 12 (counter 0) terminal and at each rising edge of the clock, the data is written.
- I have implemented the above two things but now I want to start writing the data only when a falling edge has been seen ( using PFI 0- software triggering). How to do this?
I'm also getting this error if I run this program -
error -200452 occurred at Property Node DAQmx Trigger (arg 1) in DAQmx Start Trigger (Digital Edge).vi:1->output_new_withtriggering.vi
Possible reason(s): Specified property is not supported by the device or is not applicable to the task. Property: Start.TrigType.
Any help is appreciated. Thanks.
01-22-2013 02:37 PM
Hi Easwar,
You can use the example Digital - Continuous Output.vi at Example Finder. I believe this example will work for you. You can find it at Example Finder>>Hardware Input and Output>>DAQmx>>Digital Output.
Best,
Carmen C.
01-23-2013 02:48 AM
Thanks for the infor. I already tried that but am still getting the same error.
01-23-2013 09:33 AM
Hi Easwar,
I found info that might help you. Please refer to page 6-3 of M Series User Manual.
Best,
Carmen C
01-23-2013 07:08 PM
Thanks a lot Carmen ! I was able to figure it out but I dont want to trigger the clock.
When I trigger (falling edge) has been made, the data has to be written.
For example when I click run,
clock - H L H L H L H L H L H L H L
trigger - H H H H L L ................L H H
data written - ------------1 0 0 1 0 0 1 0-------
