12-14-2012 02:41 PM
I have NI PCI-6110 DAQ and I have input TTL signal of 15 MHz. I was thinking to acquire this signal using DIGITAL INPUT. Is there a way? If yes, can you please illustrate with an example? Your help is highly appreciated.
Raj
12-15-2012 01:25 PM
12-16-2012 09:38 AM
Thanks Denis. I will have a look at it on Monday. I have a device that sweeps in frequency (14-18 MHz) and was thinking to know exact instance of the change using the DIO or lets say counter. If it can work I can use this DAQ otherwise, can you suggest some good DAQs?
Thanks again
Raj
