Digital I/O
Digital Channels do not appear as an option for physical channels
I want to create an external timing source, so I used the "create timing source" vi as a "digital edge counter". This means that I have to specify a channel for the input external clock. However, the physical channel constant lists only analog channels and not all the channels.
Do you know how to make the digital channels appear?
(5,201 Views)
Hello Evangelos,
Thanks for posting at NI forums! If you right click on the terminal and select I/O Name Filtering, and you check those options, are you able to see those terminals? If not, what device are you trying to use for that task?
Best Regards,
Alina M
(5,179 Views)
Yep, or right-click and "Create Constant" off the terminal and the appropriate filter should be applied...
(5,176 Views)
Ok, I found it. Thanks!
(5,168 Views)
