02-10-2016 09:35 AM
Hi all,
I have a question regarding overcurrent/overvoltage error detection of the NI 9476 digital output module.
As I understand it, if using the module in Scan Interface mode, only a module-specific error 65548 is supported, and it is not possible to determine which channel the error is on. Does this mean that none of the channels will be controllable, since attempting to write to any of the module's I/O variables will result in an error? Also, is it possible to debug which channel is faulty (e.g.using the Distributed System Manager, testing each channel on/off in at a time) without having to resort to FPGA interface mode?
Dimitris
Solved! Go to Solution.
02-12-2016 05:14 AM
Hi Dimitris,
I believe are you are correct that in Scan-mode this error means that the you cannot write to any of the channels, and unforunately there is no way to debug which channel has caused the error without going into FPGA or testing each of the channels individually. Please see this forum post for checking the channels using FPGA.
Hope this helps,
Tom
AE, NIUK
02-15-2016 05:21 AM
Thanks for your reply.
I was afraid this would be the case with Scan mode.
Dimitris
