04-06-2016 02:58 PM - edited 04-06-2016 02:59 PM
Hi guys, I'm new to pyDAQ and I'm just trying to send out a Digital waveform through my python code.
There is sooo much documentation that every time I get close to a solution, I get lost...
I try to run the following:
from PyDAQmx import * import numpy from PyDAQmx.DAQmxConstants import DAQmx_Val_ChanForAllLines, DAQmx_Val_GroupByChannel # Declaration of variable passed by reference taskHandle = TaskHandle(0) try: # DAQmx Configure Code DAQmxCreateTask("",byref(taskHandle)) DAQmxCreateDOChan(taskHandle,"KeyDAQ/port0/line0:7","", DAQmx_Val_ChanForAllLines) DAQmxCfgSampClkTiming(taskHandle, '/KeyDAQ/PFI4 ',10000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000) data = [0,1] arr = numpy.array(data, dtype=numpy.uint8) DAQmxWriteDigitalU8(taskHandle, 100, True, 500, DAQmx_Val_GroupByChannel, arr, None, None) # DAQmx Start Code DAQmxStartTask(taskHandle) print "Generating digital output continuously. Press Enter to interrupt\n" except DAQError as err: print "DAQmx Error: %s"%err finally: if taskHandle: # DAQmx Stop Code DAQmxStopTask(taskHandle) DAQmxClearTask(taskHandle)
and I get
DAQmx Error: Specified operation cannot be performed while the task is running. Task Name: _unnamedTask<0> Status Code: -200479 in function DAQmxStartTask
I know I probably don't have the right direction, so could someone point me what I should look for ?
04-07-2016 08:50 AM
Hi Sdemmer,
There is a KB article on the same error code. The error can be caused by calling the DAQmx write or read function before DAQmx start task, which is what we have here.
I am not an expert in python or pyDAQ, but I believe pyDAQ is simply a wrapper for the regular DAQmx dll. The error code in pyDAQ should match DAQmx error code as well.
