08-30-2014 05:07 AM
It was recommended to me to use the DAQ change detection function that returns a BCD to indicate which lines have had state changes. Does anyone know of this function, and it it is DAQmx or Traditional DAQ?
Thank you.
Danielle
09-02-2014 09:41 AM
Danielle,
Check out this link which gives an overview of change detection using NI-DAQmx. It depends mostly on your hardware.
http://www.ni.com/white-paper/4102/en/
09-02-2014 11:30 AM
Hi Brad,
I saw that white paper before. I am just looking for the name of the method described above. I have a USB 6509. I am using C, not labview.
Best,
Danielle
09-03-2014 09:20 AM
There are text based examples that install when you install DAQmx. They are located at Start » All Programs » National Instruments » NI-DAQ » Text-Based Code Support » ANSI C Examples » Digital » Read Examples. There will be examples on how to do change detection in C.
If they are not installed follow the instructions here to install them.
http://digital.ni.com/public.nsf/allkb/E3BAF6FC4017960B8625755A00525D37
Here is a link to the C Reference Help for DAQmx Functions
http://digital.ni.com/manuals.nsf/websearch/6A79EF4F9F30AFC086257A4400600861
