09-02-2013 01:15 AM
I have to generate a 12 bit combination Digital output . I made a vi accordingly but on fixing the prob the out is showing, but at DAQ output the response is not the same while checking with multimeter. I am using NI USB 6009
Please help me to solve this
Thanks in advance
09-02-2013 10:56 AM
None of that code makes any sense at all, And sorry, but I don't understand your question either.
09-02-2013 03:23 PM
It is quite likely that the USB-6009 is producing the outputs you write to it. Are you sure the numerical and boolean manipulations are doing what you want?
Here is a cleaned up version of your code without the DAQ Assistant and with indicators connected to all the calculation outputs. Run this with various values of Frequency and see if you get the results you expect.
Lynn
09-02-2013 09:25 PM
thanks for the support
09-04-2013 07:28 AM
Brilliant sharing post.
